Originally Posted by mgoblue9798
Make sure to write down notes on the sparying- ie gun inlet pressure, pattern width, distance of gun from sheet metal, etc. They can all make a difference in how the metallic lays down. It is easy to forget those things if there is much of a time in between painting different panels. Notes on thinners used and air temp in the shop would also help.
Great Advice...Thank You
1969 Superbee 440-6
1977 D-150 Adventurer
2000 Jeep TJ
2018 Challenger Scat Pack Shaker
2019 Ram 2500 CTD
