Originally Posted by gtx6970
Originally Posted by topside
I've used both VHT & Eastwood with xlnt results.
Main thing is to apply heat & a fair amount of the paint.
For bare metal, I first lay down some semi-flat black.
Heat gun works very well.
Thanks,
While I have them off . I would like to repaint them . As I think the finish is way to smooth ( going thru the valves and cking valve stem seals )
I used to like the coarse finish for black wrinkle. Until you have to clean it. Then it's not so attractive.
"We live in a time when intelligent people are being silenced so that stupid people won't be offended".
