with a daul line system on stock hemis with stock mounts,use the milidon pump with the front pick up entrance and the front pickup sandwich plate between the pump and the block if you can use the side fitting in the cover plate and turn the fitting towards the front,just a few options.Remember to use the correct length intermediate shaft for each application.For steet application we usually plug on fitting at the pickup on the pan and run a single line system for under 7000rpm use.
