yes, its on the second one, also the pump shot has been drilled out. Demonsizzler who used to be on here went through it. Just weird how i can stab the throttle to 80% and no ping, but go that last little bit and she pings even though theres not much of an RPM difference, thats why im thinking that when the secondaries are all the way opened it goes lean for a second
To state the obvious, air moves faster than fuel. Might be that the secondary is opening just a bit too fast. Have you looked at that?
