Ordered the adjustable steering rod kit from hotchkis. I suppose A person could use the stock sleeves and just order rod ends, studs, and spacers somewhere. Should allow me to ditch the tie rods and replace with rod ends, which should allow for more adjustability in raising the tie rods (rod ends) since the rod ends are smaller than a tie rod. Hopefully correct the bump steer. Will let you know how it works out. In the mean time, I will add more positive caster angle back into the front.
