Originally Posted by n20mstr
ARC is what i have, it makes it really easy to do it neatly . Works really well
I was leaning to one of these and eliminate the stock key start.
Not sure how to bypass and use the ARC panel start switch.
i still use the stock starter relay. Just use the ARC panel to provide 12v to the relay on the small stud.
This is what we did also
