Originally Posted by hemi-itis
Cam still needs to be degreed in.
up iagree
I've had to many cams and timing sets that where off more than 2 degrees both ways, advanced and retarded downwhiney
OP, do not use just the dots to install your cam, use a degree wheel to verify cam timing off the lifters and adjust as needed up scope wrench
