I have the following componants. Dednbear command center. B&M ratchet shifter. CO2 air shifter. RPM switch that fires the air shifter. I. want to install a safe neutral valvebody by Transzact. With the current setup the airshifter is fired by an rpm switch in the digital 7 ignition. I need a safe way to interupt that rpm signal after the 2/3 shift or the shifter will go to safe neutral before the traps. For referance the safe neutral vb pattern is PR123N. I will have to check and see if i can set up a timed grounding circuit and connect the ground for the airshifter to it? At this time i only use one of two circuits from the command center.
