nut... You going to lose the springs and torsion bars ?
Doc , All that stuff was removed when it was turned into a race car.
I have a set of hinges alone that I have been massaging and mocking up and they actually look like they will work out.
Because of how the hinges layout vs the lid I will have to cut into the and remove a section of raised support you see on the underside of the lid . Thats where I will attach a 2x2 piece of aluminum angle to bolt to the hinge.
Ultimately I will epoxy and glass mat the angle in once I have the angle in the correct position.
Is there anything I can use to like glue , or contact cement or???? to temporarily put those angles on good enough to mock up and test position? Something that could be removed to reset the angle if wrong?
