One of the poly kits has an oval, steel insert; the other does not. I would buy the one with the insert. Check Rockauto for good prices.
EDIT - the Energy Suspension ones have the captured insert. If you look at the same set in red you can see it. Don't forget poly for the torsion crossmember, too.
