Re: How much timing chain stretch before a - .005 set ?
[Re: Dunnuck Racing]
#286612
04/13/09 08:33 PM
04/13/09 08:33 PM
Posts: 1,283 Colorado,U.S.A
4404dart
Colorado,U.S.A
Here is a bump for you. By the way,is that rust on your cam gear,or some sort of grease?
It's an optical illusion? No it's the set from last year, but when I installed it on the other motor, it had about the same play. I ordered the same progear set, and was told the same thing as what you guys are saying, " fergetaboutit". I thought it was a little loose, but I guess not. Thanks to all that replied! ![](/ubbthreads/images/graemlins/thumbs.gif)
![](http://i154.photobucket.com/albums/s255/haleyld/MGPcoppergasket540005.jpg)
