I had a SRP forged street piston fail with a Scat I beam rod while warming a stroker pump gas street 340 motor up on a engine dyno to get the oil temp. above 130 F and break in the cam at around 2000 RPM in less than 15 minutes whiney The wrist pin, one rod bolt and the rod where in the oil pan after the rod putting a hole in the side of the oil pan with no warning puke whiney
I sent pictures to both Scat and SRP, SRP ask me to send them the piston as one side of it had broken off at the bottom of the ring land and let the wrist pin fly rant SRP did nothing about that other than say they didn't know why it failed after looking at it down
My message is don't buy the cheapest parts based on price if want better parts in your motor and no problems later work
