All 440 HP Motors where 750cfm - High Performance or HP Engines 1968 - 1971
Model # is on front passenger side base plate if it doesnt have a tag
The smaller Carter AVS was rated at 630cfm - 383 and 340 Engines and Non HP or Low Performance 440 Motors
Easy way to tell a 750cfm Carter AVS if its off the car , flip it over , all four throttle plates are the same size 1 11/16"
1971 Dodge Charger Superbee
2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded
Siberian Huskies
