I believe the “smooth” ones were very crack prone out along that lower region....... which is why the ribs were added...... to stiffen that area of the casting.
The W2 aficionados can probably speak to that.
68 Satellite, 383 with stock 906’s, 3550lbs, 11.18@123
Dealer for Comp Cams/Indy Heads
