Wanted to see if anyone has used the 3" TTI exhaust sys with springs moved inboard? I currently have the x system with turndowns at the axle. TTI says I need to run mufflers with both inlet and outlet on the inside (toward the tunnel), and a fuel cell in order to run their tailpipes...which I would like to add. Already have the fuel cell, but im wondering if with this configuration the pipes are too close together on the backside? I havnt been able to find any pics, would anyone happen to have one to see how that looks? Thank you!
