There still is a sensor that gives a signal that the computer sees. The computer can be programmed for the specific tire used. Common procedure is to use roll out basically tire diameter as a factor to use in the programming procedure. Dealer can do it or you can buy your own to do it yourself. Here is a video.speedo calibration
