Originally Posted by TJP
Originally Posted by moparx
the cooler lines are 5/16" and the nuts/fittings should be common parts store items.
beer
I'm not too sure the Female inverted flare nuts are going to be available at the local parts house. most around here don't carry a lot fitting wise wink beer
Usually compression fitting union nuts will work fine.
July 19th should be "Drive Like Rockford Day". R.I.P. Jimmie.
