these had the Chrysler markings on them and there out at the moment
BE&A was in partnership with PG Classics. BE&A's parts were run first, then the part numbers were removed from the molds. Then PG's parts were run. Once BE&A is out of a part that has the correct #s on it, they have no way to get more. The numbers have already been removed from the tooling that makes the parts. At least this is how it was explained to me years ago. I hope you find what you're looking for. You should start a want ad in the "Parts Wanted" section.
