Tom will tell you HP means squat. He will ask you bob weight, rpm limit, and if it's a power adder motor. Mine runs a Molnar 4.500/2.200 crank and their 7.100 rods. Bob weight is 2222. Motor has a 7400 chip. Over 300 passes. Car has been 9.0#150@3350#.
Doug
If I was doing this combo I would use a Molnar crank and rods up to 900hp and 7500-7800rpm. Tom has put a LOT of R&D and analysis into his products. If you are wanting to make more power or turn more RPM I would use aluminum rods. They are WAY easier on everything else. R&R, BME or GRP are good choices. They will last 300 passes as long as they are heat soaked before the first pass and you don't motor down on them. All the OLD myths about aluminum rods are just that. MYTHS.
