I’ve heard before that it makes it easier to loosen up the main caps to pry crank up slightly to make it easier to replace seal. Is it possible to pry it up slightly with the timing chain? I’m not quite sure that it can pry up in the rear only. I think it has to go pretty straight up to lift up from the main webs. And is that really necessary, or is it not really easier doing that? Engine is still on stand before installation in car. Thanks.
1.50 60Ft. , 10.75@ 127MPH Hauling 3900 LBS.
