in my opinion 600 hp for sure is solid roller territory, the stock hydraulic roller setup is not usable - no advantage for the Magnum. I think either platform can be used, but honestly i think the Mag 5.9 blocks are available in better condition to start with. Valvetrain oiling has to be considered, but there are solutions to use mag heads on LA or LA heads on a magnum.
Regarding the intakes: there is a Indy 360-3M intake available with mag-style bolt pattern, so this is no deal breaker.
Michael
The Indy 360-3m is the best magnum intake out there, that's what I use on my Magnum build, it was heavily ported by Shane Studley, Precision Cylinder Heads. He was not impressed with it out of the box. I'm using Bam Solid rollers and Jesel shaft rockers for the reason you mention....640 lift cam.
