Nothing against anyone that has taken on one of the high end builds, but it's no where near the same as building a 10.00 car. Even after the car is built, the money flow, is just starting. Dialing in a combo like that is not easy, nor cheap. It also requires a LOT of help from other people. If you do not have a couple competent people helping you, it just doesn't get to a point of where you are happy with your investment. The money drain just burns people out.
AMEN!!! Kinda right where I am at right now.
