Originally Posted by RAY1969CARS
Does anyone run these on a 10 inch rim ??? If so can you post picturesDrag radials
10 inch rim is pretty common. But remember that the wider the rim, you have to go on the higher side of the air pressure to support the center. A wider rim and the tire wants to cup in the center.
....BAD A$$ STREET CAR.....
