Anyone install the 14" x 6" reproduction Mopar rallye wheels on their A-Body? If so, what trim ring did you end up using?
Reviewing Summit/Jegs websites, indicate the 14" x 6" trim as a shallow ring with a rounded edge? The 14" x 7" trim ring appears to be more correct for a 1970 Mopar with more depth and a step/transition on the face. Any info on part number/supplier info would be greatly appreciated.
Anyone try installing reproduction trim rings on original 14" x 5.5" Mopar rallye wheels? Quality fit or issues?
