A fresh build, or an original untouched motor?
What have you done or checked, other then replacing tune up parts?
Not much info. We will be guessing for months! Gene
Probably 50000 miles. Running great when parked, about 2 days later this issue raised its ugly head. Tune up parts only. I have not checked timing, plan on getting to that tomorrow (Monday). Did adjust air fuel mixture, no help. Considering new distributor, but hoping the timing will help. Do not remember checking timing, ever. Replaced plugs and wires several times, just never checked/adjusted the timing...
