3800lb RR with me, Cal Trac Mono's/bars, bottom hole, 2 flats preload either side with me in the car which leaves a nickel gap on drivers side when out, Strange double adjustable shocks on back, single adjustable front, 30x9-15 C07 Hoosiers @18psi, pump gas 505" with max wedge ported Indy EZ heads by Dwayne Porter, .670 ish Comp roller cam, 4.10 Dana 1.43 - 1.46 60's depending on track/heat conditions, best to date with current set up is 10.34 @ 130.70 in 90 degree heat. Important to note I am taking 14* of timing out at the hit and ramping it back in for 2 seconds with MSD grid to act as traction control for the 9" radials which works very well and consistent 60'.
