Really 183? Rumor had it that later-model 5.9's had larger 163cc ports (versus the 5.2L 153cc ports). The casting number you refer to is supposed to be the larger 5.9L head.
Did you measure before porting? Did you really take 20cc out of the bowl or did you go into the throat and runner to get that volume?
