Amazon has them for a lot less, put the Ford part numbers in the search there.
You realize that Ford, in their infinite wisdom, but one timing set on the back of the engine necessitating the removal of the engine or the trans to do the job, they claim you can separate the two to get enough room, didn;t work for me.. BTDT with my daughter's Exploder. You really need the proper tools to time the engine as they aren't keyed and misalignment is probable without the timing tools. You can get those on Amazon too.
https://www.cloyes.com/1997-2011-fo...-timing-replacement-cloyes-kit-9-0398sb/
