If you do find the correct terminal at McMaster, can you post their part number here? Would be handy to have.
The part number for the .187" size is 69525K19, which is for 22-18.
I haven't been able to look at them yet, but can someone confirm if these are right? I probably have one on my original harness if you want me to clip it off.
Jeff [/quote]
If you could measure it simply for research purposes that would be great. It just seems like it's too hard to find a connector in this size if it was OEM.
