Originally Posted by STEFF
It was a Short Deck Donovan Solid BBC Block that was partially machined, no Lifter bores etc.... If memory serves, LSM Engineering in Michigan did the machine work for mounting the Heads to the Block and Lifter Bores. I believe Mike from Muscle Motors had a hand in it as well.
Exactly. I had just started working at M.M. when that project was going on. Then I was at PTC a little while back and Kenny and I was talking about the history of the motor.
