The foam blocks are placed in there to keep/contain fuel in the cell in the event that a hole is punctured into the fuel cell. .should that happen , it will help hold the fuel so that it does not just pour out in a large pool all at once . they do not displace that much volume of fuel.... if you get cheap foam , you will learn how frustrating it can be to get the dry rotted pieces out of your fuel system........
