Maybe some change, maybe not confused
I would try it to find out up
My car came with that green/blue lube in it, the former owner had ran a blown aluminum B1 on alcohol with 5.86 Pro gears in it and he told me he never had a gear problem wit that lube up work
I order what I thought was the same gear lube but I didn't know the correct part number and ended up ordering both the lightweight and super lightweight gear lube to have it when I swap the 4:56 for the 5:86 gears in the rear end.
That gear lube pours out of the bottle cold like ATF does shock up grin It is really good stuff, get you some of that up
I'm a little scared to try the super lightweight do to the old adage of not fixing what isn't broke work realcrazyshruggy
