Good morning everyone, I'm having an issue with the R/T emblems on a 70 Challenger, mainly the fender. I have received the "pin style" repops, but they are tapered, and the pins are too close together. The casting on these is 3445223, which is the correct number according to the Mopar parts book. However, the original emblems are flat, the pins are spaced farther apart, and the casting number is 3445231. When I questioned the repops, they told me they were correct, as the grille emblems had longer pins. Well, thanks, but, the grille emblem 2998547 does have longer pins, and is flat, not tapered as what was received, both locations. The so called fender emblems are tapered, as stated, but even if the holes lined up the emblem would not sit flat on the fender, almost like it's meant to sit along a body line. Has anyone else had this issue? Should I just go with the stick on replacements that are actually the right size and shape, just no pins?
Thanks Moparts!!
