Originally Posted by 3hundred
I just recalled those carbs were jetted insanely lean, led to burned exhaust valves. The carbon canister is failure prone, carbon pellets can enter the float bowl and are just the right size to plug the main jets. I used to use a fuel filter in the vent line to keep debris out of the carburetor.
88 318's where injected. the 360's got the carbs. WHOOPS 86...
[IMG]http://i66.tinypic.com/pui5j.jpg[/IMG]
Coming soon!!!!
