Last time at the track i was going thru the traps at 7050 and would get a pop out of the engine once in a while. Thought i may have been tickling the rev limiter which was set at 7100, i now am thinking that the valves were barely under control at that rpm. not sure, but i know my shift points will be below 6500 this time out. I may have to run 1/8 mile only. Will see. Thanks
