Originally Posted by lewtot184
you can buy another set of kb107's in .020" or .030" for less than $300 dollars. that's cheap! so why waste time and money with custom pistons if the KB's will work?
No way would I go with a set of custom pistons.. why go that way when you bought a set
of inexpensive ones to begin with.. you might end up going .020 over KBs but then
you would need a bore job if the block allows it
wave
