I hope it includes the wife's 2018 Jeep Compass. It has the 2.4L and consumes oil between oil changes more than I like. Dealer said a quart every 1,500 miles is considered normal. Really? That's over 6 quarts of oil between the recommended oil change intervals and the engine only holds 5. Plus it uses the expensive stuff. Wife loves it, so adding oil if need be is a small price to pay, but one I shouldn't have to do.
Exactly why I have had a hard time even thinking about coming back from the 'off-brand' I am currently driving. 267K miles...zero oil consumption and I ran it 5K between changes. Finally had a head gasket failure. Just did a JDM swap and should be good for another 200K. I will pass on these things. GM used to say the same thing about what was 'normal'.
