IIRC, you have an extra few hundred pounds (or more?) of alternate fuel equipment on your car. Extra weight means accellerated wear, which would seem consist with your need to consistently crank up the resistance in the shocks if they were valved for a lighter weight A body and you are closer to fully loaded B body weights.
