Originally Posted by moparx
when installing the yoke on the pinion, apply a little rtv on the splines to prevent any wicking that may appear to be a seal leak.
also, if the seal has a garter spring facing the pinion, pack that area with wheel bearing grease to prevent the spring from popping off the seal when it's being installed.
beer
up Listen To what the man is telling you twocents beer
I've even been known to add a bit of sealer behind the washer wink
