Originally Posted by NachoRT74
Well, the pink wire is connected because it turns on with the switch, just not with doors.
Wrong. The Pink is hot all the time. Yellow is the switched to ground to complete the circuit. The map light has one other wire I think black that is a fixed ground to the map light can work independently from the door switches.
