The problem is that most likely all the aftermarket companies are sourcing their parts from the same Chinese supplier. So if the supplier is using the generic casting with outlet bosses on both sides, that’s what you are going to get now unless you luck into some older stock. Rebuilt might be a better bet, but even with that you run into the risk that many rebuilt master cylinders are bad right out of the box.
