Hoosier 9 x 30 radial - 21 - 22 lbs works best for me any higher the pattern on the slicks shows the edges are not in contact with the track - any lower the sixty starts to fall off - a good sixty for me is 1.40. with radials its all in the shocks - double adjustable all the way around helped immensely.
