Call 1-800-992-1997. Speak to a customer service agent and advise them you would like to meet with a FCA business center rep at the dealer about your problem. There are oil consumption tests that have to be met before the dealer will work on the engine but crop dusting is not acceptable. Have you checked to see how much oil you use in 1K miles?
Nicely tell them that crop dusting doesn’t look good either.
Thanks for that info, will call them today.
We checked the oil at the dealership and it was down a full quart after roughly 4k miles. The same dealership performed the oil change. They advised me to get another change done, ensuring the level was at full, and then bring it in every 1k. Not ideal but I can do that if need be.
