Well I need to check to see if i have dual pattern bell housing first ! i purchased the floor hump for the A833 because of the obvious Shifter location issue..i will probably use the OD trans.. i know the bearing retainer is the larger of the two
2005 Dodge 1500 Slt Hemi
2008 Chrysler PT cruiser
1984 Dodge D250
1978 Dodge D100 Adventurer
1964 Meyers Manx Dunebuggy
