Yeah, they weigh a ton.
Something I forgot to mention is that they're also longer front-to-back than HPs.
So the right side doesn't fit later Bs with their engines set back further than the early cars.
On my '63, I had to add a heat baffle for its dual master cylinder.
Found that out on its maiden half-four drive when the brake pedal got real mushy...
