Originally Posted by madscientist
That’s a geometry issue. He may have too many threads showing on the adjuster, but that didn’t cause the failure. Also, if he machined the spring pockets for clearance that will cause a failure. That goes back to incorrect geometry.
Have him go to b3racingengines.com and read all the tech threads and then have him order a geometry correction kit.
This. thumbs
"use it 'till it breaks, replace as needed"
