Originally Posted by GoodysGotaCuda
There's another reason why you shouldn't put 4 point harnesses in a street car. Would have been pretty bad had he not been able to lay over.
I disagree, if you have a 4 point harness in the car it normally is installed along with a roll bar also, correct?
The roll bar may have kept the roof of that Mustang above the drivers head, if everything was installed correctly with the fictitious harness and roll bar work
I'm glad he is alive and walking and talking about the accident up
