Originally Posted by cudaman1969
Mine doesn’t look like that one, older. I made a plier type gizmo that holds the ends so they come together on the points, about 30” living to points made like a big C. Press together hard, push the trigger. I set the duration and amps before hand.
Can you show a picture id the tool that you made for the welder
