Originally Posted by Runner
How big of a tank do you use for the fuel tank gor the nitrious system and where is it located? I've kicked around the idea of spraying a 150 shot on my roadrunner.
It is a JAZ Jr. Dragster quart fuel cell. I mounted it next to the radiator on the core support to where it looks like the overflow tank. The real overflow is underneath it and so is the fuel pump. I was able to use the existing holes that were for the horns.
'63 Dodge 330
11.19 @ 121 mph
Pump gas, n/a, through the mufflers on street tires with 3.54's. 3,600 lbs.
10.01 @ 133mph with a 250 shot of nitrous an a splash of race gas. 1.36 60 ft. 3,700 lbs.
