The purple and the yellow ends have been hot at some point and have lost their strength. I have fought this for years and have been able to limp along until recently.
The pins measure about .091". If worse comes to worse, I may be able to use .157 female bullet connectors. I would need to open the split up wider so that I could size the connector down to the .09" range so it would grip the pins. Then there is the issue that those connectors shoot straight out from the switch rather than turn 90*. There may be interference problems.
It sure would be easier to find 2 of those connectors or 2 wire ends with those connectors on them.
